Post new topic Reply to topic  [ 7 posts ]
CEL coming on above 3000 rpm on MC-II...
 Post subject: CEL coming on above 3000 rpm on MC-II...
PostPosted: Sun Dec 19, 2004 8:10 pm
Any ideas what it is? It seems to do it regardless of load.
Alan
1990 200q - 034 EFI stage 1B Parting now
1990 CQ - 3b swap in progress
PostPosted: Sun Dec 19, 2004 9:13 pm
master of teh modz
Did you pull the fault codes?
Don't Panic
Contact me with any site/registration problems: nstuart -at- 034motorsport.com
- Douglas Adams
PostPosted: Sun Dec 19, 2004 9:24 pm
its prolly the knocka sensor or the air intake temp... however if its regardless of load, my guess is the knock sensor.....
the air intake temp sensor is a common fault, but usually only manifests when the WOT switch is triggered... however, the knock sensor comes into operation aslong as the engine is above 3000 rpm.... if i were you i would check the electrical connections on both...
if you know how, do a drive and trigger the CEL and then check the codes..... thats your best bet...
nate
Nate's Law:
The greater the number of people in the group, the lower the total collective, and individual intelligence of said group becomes.
Audi, imprisoning me, all that i see, absolute horror. I cannot live, i cannot die, trapped in my audi, my audi my holding cell..
1988 Audi 5ktq - 10vt Ms&s Extra
1993 Audi 90q - 12vt
PostPosted: Sun Dec 19, 2004 9:32 pm
I was thinking its the knock sensors. I haven't checked the codes before, but after reading up on SJM Autotechnik it looks like I have to buy an led and and a resistor to do this? Also, would this cause the MAC-14 to pull back on the timing? Because I seem to be down on power.
Alan
PostPosted: Sun Dec 19, 2004 9:40 pm
yes , an led and resistor is like 2 cents.... and yes it would cause you to lose power
do you have noisy lifters? lol
thats generally my problem.... if i get a lifter ticking alot it tricks the knock sensor
nate
Nate's Law:
PostPosted: Sun Dec 19, 2004 9:42 pm
Ahh I did notice my lifters were *really* noisy after I was out and about boosting :) So noisy that I checked my oil to see if it was low. That could be the problem.
Alan
PostPosted: Sun Dec 19, 2004 10:48 pm
If you've got the CEL, then just use the fuse in the FP relay. It worked on my car...
Rob Dupree
2013 Porsche Carrera S PDK - [un-named]
2007 VW Touareg V10 TDI - 'Hank the Tank'
1984 Audi Ur Quattro - "lil'Red-T'matr"
1987 Audi 4k 20vT Q Racer - 'Lava Machine'
  |  It is currently Wed May 22, 2013 7:53 am
