Post new topic Reply to topic  [ 11 posts ]
engine parts
 Post subject: engine parts
PostPosted: Sun Jan 02, 2005 12:58 am
well i am new to the audi scene and need some help. i am looking for header,intakes,exhaust systems. anything to do motor wise with a 1990 audi 80 2.0. i want to get a little more out of it. so if any one can give me some help i thank you. also i have seen some chips on ebay and some moduales that "claim" 7-20 hp. now i know in my world(mopar) these are a waste of money. i even found a "chip" that said stage 2 on it for audi. i guess the wire into your intake sensor.are theis crap or not. my guess is they are.
95 neon sport turbo387whp full r34 kit all go all show
1990 audi 80 2.0 realy slow some show
PostPosted: Sun Jan 02, 2005 1:09 am
:blog:
Not sure who makes a chip I have 2.0 head ported and polished w/ a hor cam in it. You would need to make some mods to it make it fit (it's a 95 jetta head) but it would be the cheapest way to go, if your just looking for little more power.
Austin
88 5ktqA 90 90Q 20v 91 200 20v 92 urS4
PostPosted: Sun Jan 02, 2005 1:22 am
what mods to make it fot????also is are head design similar to a vw jetta head and if so what yr???
PostPosted: Sun Jan 02, 2005 4:12 pm
The head on your 80 is the same or similar head as on all non-crossflow VW 4-cylinders. I'd recommend an AutoTech or Techtonics camshaft as a good way to get more power out of that mill. Try that first and if it isn't enough then go the swap route. IMO 8-valves are great engines in Mk1's and just decent for getting where you need to go in anything else.
-88 90 Quattro(x2)
PostPosted: Sun Jan 02, 2005 4:23 pm
so i can just get a cam then???what yr cam do i use.and the sight for the cam.also can i use headers or is their un intke for my car???
PostPosted: Sun Jan 02, 2005 4:53 pm
:blog:
I don't know who makes a cam for that 4cyl. maybe schrick?
Austin
PostPosted: Mon Jan 03, 2005 8:53 am
I believe you can use any of the 4-cyl "hydraulic" cams for that engine. The only thing that's really different about the 2.0 head is the intake / injector port setup.
TT (no affiliation) has a good one that a buddy used with that engine ...I believe it was a 268. His engine responded very well to that cam...
http://techtonicstuning.com/cams.asp
HTH...
00 A4 1.8TQ
98 A4 TDI V6 Avant Q
98 A6 Avant Q
86 4ktq
83 GTI FSP
81 Caddy TD
77 Rabbit ITC
96 Miata
PostPosted: Mon Jan 03, 2005 2:08 pm
cool thanks. what about intakes and such can i get one from anyone???
 Post subject: Re: engine parts
PostPosted: Mon Jan 03, 2005 5:54 pm
I boggle like it's my bidniss
Dont waste money keeping the engine in NA form.
You can get a Cam from Autotech and it will work.My advice is to seriously consider some Head upgrades.8V,16V or 20V...you choose.If you want to keep it NA then my advice is to do the following :
1. Slap on a 20V Head
2. ITB's
3. Passenger side EM from a 40V V8
4. Some form of management,maybe 034EFI Stage Ia.
If your looking @ Ebay for modifications and "chips" then your better off selling the car to someone that will not torture it.
Best of Luck...
Issam N. Abed
034Motorsport major Distributor for Canada
INAEngineering.Com
PostPosted: Mon Jan 03, 2005 7:21 pm
Due to the nature of the fuel injection on that engine (and CIS VAG products in general), no one really makes any aftermarket intake manifolds. You can't do cone filters or large intake piping due to how the stock injection works (fuel metering head, air box, etc.) The stock pieces do quite well in their stock role in the system.
Next, due to the limited space on these engines, no one (that I know of ) has made a header for the Audi 2.0 4cyl, VW Fox and Audi 4ks (fwd).
Wizza's right that you could a hybrid with other multivalve heads, but this, depending on your ability is pretty involved and would undoubtedly involve some fabrication.
I had one of these 80's for a while and I figured about the most you could do (within reason) is put in a better cam, do some head work and get a better (custom) exhaust. Mine was tired and it never made it that far...
00 A4 1.8TQ
98 A6 Avant Q
86 4ktq
83 GTI FSP
81 Caddy TD
77 Rabbit ITC
96 Miata
PostPosted: Tue Jan 04, 2005 4:33 pm
cool thank you
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
  |  It is currently Sun May 26, 2013 1:04 am
