motorgeek.com :: Board index :: The Tech Lounge :: Suspension
Post new topic Reply to topic  [ 108 posts ] Go to page Previous  1, 2, 3, 4, 5  Next
The DIY Coilover page for 80/90/Coupe
PostPosted: Tue Jan 19, 2010 3:24 pm
Anyone know how low the 7" spring will be, I want the car to be pretty low, Cause QA1 springs only have 7" and the Eibach's have a bunch of 6" springs
02 VW 1.8T 7.3@102mph on pump, street tires in a converted Gti to haldex
2004 audi A4 1.8T converted to quattro- soon 2.7T swap
2011 JSW TDi 6speed
PostPosted: Tue Jan 19, 2010 3:33 pm
Depends on your adjustment and spring rate ;D
Ed Hankin *All posts subject to inaccuracy due to multi-tasking and iPhone.
If you own a 1990 or 1991 Audi Coupe Quattro and live in North America please add it to the registry!
PostPosted: Tue Jan 19, 2010 3:55 pm
450 front and 650 in the rear, It will have a V8 in the front but for now the regular 10v untill i get the suspension done.
2011 JSW TDi 6speed
PostPosted: Tue Jan 19, 2010 4:40 pm
So I guess my point is that nobody can tell you how low it will be because you have ~3" of height adjustment via the coilover.
PostPosted: Wed Jan 20, 2010 6:18 pm
Peter, try here for the springs. i found the link :)
http://www.racewerx.com/springs.htm
759 AWHP, 554 wtq @ 38 psi in a 20v 2.0L 4 cyl Coupe Quattro. on E-98 and 67mm billet turbo
9.342 @ 153.71 1.400 60' and pulls 1.6g on acceleration! 60-130 in 4.9 seconds
QUICKEST 4cyl Audi Quattro drag car in the WORLD!! And now QUICKEST AUDI IN N AMERICA AS WELL!!!!
My Website
PostPosted: Wed Feb 17, 2010 12:39 pm
When welding the rings that the springs sit on to the shock body, is there any risk of burning through to where the gas is? Is this a potential hazard or is there a couple layers of metal there.
PostPosted: Wed Feb 17, 2010 4:23 pm
your sapposed to take the shock out of the tube, but I was wondering the same thing about getting too much penetration and not being able to get the strut back in.
PostPosted: Wed Feb 17, 2010 7:04 pm
you do not burn thru and make a mess of things. controlled welding..... piece of cake.
and yes you pull the strut insert out first.
My Website
PostPosted: Wed Feb 17, 2010 8:00 pm
Gotcha. I've never had one apart so I wasn't sure if you were welding directly to the gas strut or not. Thanks for the insight. :cheers:
PostPosted: Wed Feb 17, 2010 8:03 pm
look at all the pictures i posted on the first page, you will see them all disassembled.
My Website
PostPosted: Wed Feb 17, 2010 10:01 pm
Wow, there it is. Somehow I missed that one
PostPosted: Tue Mar 30, 2010 7:52 am
So, which springs (length and rate) are people using for their daily drivers that result in a firm yet comfortable ride?
Brent
2001 A4 Avant 5MT Pelican
1991 CQ - Project Car
PostPosted: Tue Mar 30, 2010 9:18 am
I haven't run this yet but I'm going 300f/325r 8" Spring all around. Should be firm but not too stiff I"m hoping. I ran 10" Springs in 325f/275r on mly 4000q and it was totally livable as a daily driver. I want a little more tail happiness though hence the inversion this time around. And with 10" Springs I couldn't lower the car really, but even at stock ride height it handled great and I was keeping up with B5 S4's at the track. (10vt engine in the 4k)
Todd
91' CQ Daily Driver (FOR SALE)
2000' A4 Avant ATQ
83' ur-quattro. "Jadis" Cage, Coilovers, No Engine Yet.
"Coupes are better than Sedans. Less Door Handles to replace!!!"
PARTING:
90 90q20v
86 4000quattro
PostPosted: Tue Mar 30, 2010 9:32 am
What's this I hear about decompression clunk on these coil over set ups? Is this really an issue?
PostPosted: Tue Mar 30, 2010 9:47 am
Not if built right.
I never had an issue with 10" Springs because it at the ride Height I had them set at the spring never came unseated. I had them pre-compressed about 1-2 turns on the perch.
With 8" Springs just run a spacer/joiner and helper spring. Thats what KW, H&R and any other properly designed "system" does. I like A_CQ's thought to ziptie the spring to top perch. I imagine it would still make a little noise but would be better. Some companies also use urethane isolators on the perches to quiet them down a bit.
Todd
2000' A4 Avant ATQ
PARTING:
90 90q20v
86 4000quattro
PostPosted: Sun Apr 18, 2010 4:28 am
Wont the stock shocks wear out faster though because theyre designed for a certain hight and now theyre compressed more? I want to make my own coilovers aswell just this worries me
1990 CQ 190k silver/black
PostPosted: Sun Apr 18, 2010 8:50 am
I think the best thing to do is to use sport shocks that are made for shorter travel.
PostPosted: Tue Apr 20, 2010 9:20 am
:stupid:
If your running an adjustable setup you will be Lower & Stiffer. Both of these require new shocks. If you were just going stiffer, you'd run something like a Bilstein HD which are designed for cars that aren't lowered. Bilstein Sports/Sprints are for lowered cars and their travel is different.
That said, valving is valving to a certain extent. I've heard differing schools of thought. Some say you have to be in the sweet spot of the shock. Others say it doesn't matter, as long as your somewhere near the middle. One of the main reasons Bilstein Sports are much shorter in extended length is to keep drop in OE Replacement springs from un-seating at full droop.
Todd
2000' A4 Avant ATQ
PARTING:
90 90q20v
86 4000quattro
PostPosted: Tue Apr 20, 2010 12:14 pm
I also think bottoming out is a problem as my shocks are stock and I bottom out. Probably not too long before they blow.
PostPosted: Wed Apr 21, 2010 12:20 am
what would be the lowest you could go using stock shocks? without hurting other suspension parts? i drive an 88 audi 90q and would like to lower it using this set up, but want to be able to adjust my camber and alignment to specs. is this possible??
thanks!
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
PostPosted: Wed Apr 21, 2010 7:46 am
You've got a 22 yea old car, that you want to lower and put on stiffer springs using the stock struts. Do you know if they've ever been replaced before?
That thing is going to ride like hell...
'89 90q Rallycross car
'86 CGT G2 Rally car
'00 Jeep XJ SWEEP rig
'86 Honda Magna 2 wheeled kergigger
http://www.flickr.com/photos/47757586@N00/
PostPosted: Wed Apr 21, 2010 9:19 am
alright, i will definitely look into some sport shocks! what spring length and rate should i use for a little tire tuck and fast cornering/handling??
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
PostPosted: Wed Apr 21, 2010 9:43 am
My cq rides pretty good on lowering springs and I even had to put in a cheap ass sensa track on one front corner. It definetely bottoms out though on big freeway dips and it's only a matter of time before they will be ruined. At that point I will buy some shorter travel sport shocks starting with the front.
PostPosted: Wed Apr 21, 2010 9:46 am
what size springs?? what rate? how much is it lowered?
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
PostPosted: Wed Apr 21, 2010 9:59 am
I'm talking about aftermarket springs, not coilovers . But the point is I think I'm still about as low as you would want to go in the front because my a arms are level with the ground and My stock shocks just aren't doing it but it is driveable.
  |  It is currently Mon May 20, 2013 6:31 pm
