Its spring cleaning time and I have a ton of spare audi vw parts in the garage that need to be out of here so we can get some free space back and some real work done.
I have pics for most of it just email or PM me
ttsampson@hotmail.comv8 torsen 4.11 rear diff $350
3b FW/clutchand PP VERY VERY fresh clutch, full kit $200 obo
4kq speedo cable, $10
4kq brake prop valve non leaking a lil crusty $40
b4 front window regs, driver and passenger 60 each
4kq ps pump , lines, resevoir and steering rack, complete no leaks at all, make offer
4kq front and rear knuckle/uprights, hubs brakes springs and struts, rotors and pads are good, make offer
4kq grey cloth/black door panels full set, make offer
cq rear window wiper motor make offer
I5
3b coil $60
3b maf $50
i5 20vt k24 coolant to block return line $30
’91 200 20v 4.11 torsen trans $250
034 i5 block breather hoses, one with(7A) and one without the small hose T , $20
3b new machined IAT flange 6$
7a alternator bracket $35 x 2
i5 oem snub mount surround $5
89 200 10vt 3.89 torsen trans $150
89 200 10vt drive shaft, needs carrier bearing $50
89 200 10vt rear shafts and cv’s , may need boots $20 each
7a starter $40
7a bottom end 225k $100, no oil pan
7a bag o snakes,
WITH midpipe $100
cq 01a 225k, needs t/o bearing $100
200q 15x7” mesh wheels, 5/set $120
4kq oem wheels, white good shape $120
cq steering column x 2, $20 each
b3 cq o1a shifterlinkage and shifter $40
b3 cq oem center cross member $20
b3 cq pedal set w clutch master $40
t44 200 fluid res $30 w hoses
urS4 o1e trans mount arms $30
200 20v trans mount arms $30
4kq front upright/hubs $60
4kq front brakes rotors pads all good $100
10v timing belt backing plates $10
b4 green headlight washer nozzle $10
lots of misc b2, b3, b4, b5 brackets as well see pics
B5S4
b5 s4, no A/C access. Belt $20
b5 s4 exhaust manifolds $40
b5 s4 wiring harness $80
b5 s4 POS’s $100
b5 s4 snub mount bracket and snub $20
VW
BDF head, skimmed and cleaned, ready to go $250
BDF exhaust manifolds $50
AAA oil pan steel, $30 good shape
mk4 AFP vr6 internals $60
mk4 AFP 12v vr6 head, very clean $150
AFP oil filter housing $20
AFP timing chain covers, $30 each
AFP cover very clean $50
AFP vacuum bomb $10
AFP accessory bracket $20
AFP crank pulley $20
AFP cam position sensor $40
AFP ex manifolds $20
AFP oil pan alu. $60
Misc AFP engine stuff
Mk3 aba oil pan $30
mk4 aeg oil pan $40
9a oil pan 30$
Mk3 aba head and cam $100
Mk4 AEG throttle body $40
Mk4 AEG ex mani heat shield $40
