Cqt
Post subject: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 6:09 am |
| I sprinkle rubber on my Cherios |
Joined: Sat Apr 24, 2010 3:50 pm Posts: 203 Location: Upstate NY
Found out airbox isn't 3b s2. Can figure out what it goes to. Can't find any part numbers.....ugh
| Top |
billyraff
Post subject: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 8:13 am |
| Stuck in first |
Joined: Wed Jun 13, 2012 8:43 am Posts: 19 Location: CT
3b valve cover and coil cover?
| Top |
audiPete
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 8:46 am |
| mach 2 with my hair on fire |
Joined: Tue Mar 16, 2004 12:41 pm Posts: 1371 Location: Chelmsford MA
Cqt wrote: Found out airbox isn't 3b s2. Can figure out what it goes to. Can't find any part numbers.....ugh You sure about that? Its definitely type 89 based on the 895-183 part number in the picture of the airbox that includes your hand. The ABY and ADU(RS2) airboxes are larger and very different looking, the have a flat cover on top. -
_________________ 1995.5 S6 Avant Emerald/Ecru
1995.5 S6 Avant, Silver/Platinum
1991 90Q 20v Red
1991 90Q 20v Indigo
1991 Coupe Q Silver (perpetual eS2 project)
http://www.naaclub.org
| Top |
Cqt
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 9:25 am |
I brought it over to a friends house who has a 3b s2 airbox and they dont look the same. MAF inlet is considerably larger and airbox layout is quite a bit different. It doesn't have the flat plate ontop either. or provisions for one to be mounted. I dont have a ABY or ADU to compare it to and after a quick search couldnt find any great photos. However, same guy told me he has seen many rs2 units and they dont look like that. I am so confused. I even typed in that number and couldn't find anything. I thought Audi used 7 digit numbers? Also, that plate is screwed onto airbox. I couldn't find any molded part numbers at all. Any insight would be GREAT. Thanks
| Top |
Cqt
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 9:27 am |
billyraff wrote: 3b valve cover and coil cover? Entire motor is tentatively sold, Haven't gotten cash yet, but guy is coming up from long island this weekend or next to get it.If anything changes i will let you know.
| Top |
audiPete
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 10:24 am |
File comment: 3b S2 engine compartment
S2 3b Engine compartment
1991 90Q 20v Red
1991 90Q 20v Indigo
| Top |
Cqt
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 10:36 am |
hmmm. I couldnt find one without the plate ontop of it. That does look much closer in appearance, I'll continue looking for some more pictures, perhaps removed. Thanks
| Top |
audiPete
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 10:48 am |
S2 3b airbox DOES NOT have a cover...has a lot of heatshielding on the side.
1991 90Q 20v Red
1991 90Q 20v Indigo
| Top |
Cqt
Post subject: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 10:55 am |
 rs2 on left s2 on right Found a better picture. I definetly have a 3b s2 airbox. I was given some misinformation. Sooooo. It's still for sale. Thanks for the help.
| Top |
smittoid
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 5:32 pm |
| Stuck in first |
Joined: Wed Feb 22, 2012 1:14 pm Posts: 24 Location: Berkeley, CA
Is the intake still available?
| Top |
cairodog
Post subject: Re: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 9:08 pm |
| Stuck in first |
oil cooler still available? definitely interested.
| Top |
Cqt
Post subject: S2 3b airbox, oil cooler, 3b motor and more Posted: Fri Jun 15, 2012 9:29 pm |
Intake is going as part of engine as well as oil cooler. Should be getting picked up next weekend. If not, they are for sale
| Top |
Cqt
Post subject: S2 3b airbox, oil cooler, 3b motor and more Posted: Sun Jun 24, 2012 1:11 pm |
Complete engine and oil cooler gone. Airbox still available. Make me an offer.
| Top |
