Post new topic Reply to topic  [ 38 posts ] Go to page 1, 2  Next
Lightest V8 motor for a road car?
 Post subject: Lightest V8 motor for a road car?
PostPosted: Thu Jul 08, 2010 11:04 pm
What do you guys think it would be? Would it matter to a point, as well?
I'm bored, and I also own a Miata, and I've been tossing around ideas for doing a swap... I collected a ton of info on the really common ones, including SBF and LSx motor swaps which are very abundant, but sbf motors are over 500lbs, and the LS1 fully decked out is 481 give or take 20. The Audi V8 is availiable as light as 375lbs without A/c for a belt driven 40v version (not sure on the chain drive motor) so that might be it. Also thinking of bmw or merc motors, and the Hartley V8 is so out.
There is a point where you wonder, is 100lbs out of the motor worth it, when you can strip 100 out of the car, or add more power? I think it is, since 100lbs is 100lbs more than you could otherwise strip out, and for all the added power the LS1 will give you it won't take away weight to help the handling.. I'm thinking if the Audi V8 could put out 360 or so that would suffice anyway.
Any extra thoughts? I've gotten on this plug of engine weights recently, and I made a small spreadsheet. The Hyabusa motor is supposed to weight about 135lbs... there's an interesting thought, but someone else already is doing that shit here...
Also, the BP 1.8l motor that is in a stock 94+ Miata is about 430lbs with manifolds, no turbo... mine has a turbo, so a bit more. Supposedly an LS1 or etc conversion brings the weight up about 200-400lbs.
2005 Mazda-speed Miata - 3071, Hydra nemesis, FM parts, mostly stock...and slow.
1991 VW Passat - Murder!
1991 Audi V8 Blackened, served over sadness with a side of irony.
1991 Oldsmobile Bravada - Jacked by Mexican drug runners!
 Post subject: Re: Lightest V8 motor for a road car?
PostPosted: Thu Jul 08, 2010 11:47 pm
http://www.h1v8.com
many euro cars, bikes and some 'murican stuff 2
parting: 1995.5 s6. 86 4kcsq. 1990 cq. several type 44 sedans
PostPosted: Fri Jul 09, 2010 6:15 am
^^^^ What he said; granted it also comes with a $$$$ cost..
Scott
4 V8's; All gone :-(
PostPosted: Fri Jul 09, 2010 6:48 am
Although rather small the 215 Buikc V8 probably takes the win as the lightest V8 automotive engine (around 300lbs). You can also look into the Range rover engines as they are based off of that engine so weights and dims should be the same.
The northstar is a big heavy pig as is the Porsche 928 mill. If you wanted to get really crafty you could mate 2 hyabusa engines at the crankshaft and make a hyabusa V8.. Hmmm...
The Scottmeister
"With great power comes horrible fuel economy"
www.advancedautomotion.com
PostPosted: Fri Jul 09, 2010 5:24 pm
that is exactly what a hartley v8 is
PostPosted: Fri Jul 09, 2010 6:14 pm
The start of a list Showing the Buick/Rover as 315#.
Ed Hankin *All posts subject to inaccuracy due to multi-tasking and iPhone.
If you own a 1990 or 1991 Audi Coupe Quattro and live in North America please add it to the registry!
PostPosted: Fri Jul 09, 2010 6:21 pm
sorry I idn't click the hartley link.
The Scottmeister
PostPosted: Fri Jul 09, 2010 6:25 pm
buick/rover aluminium block setup is probably going to be the cheapest, and fairly light. Not sure though.
PostPosted: Sat Jul 10, 2010 10:04 am
LSx is probably the lightest and cheapest/cheapest to mod.
XLR8
2003 540i/6 M-Tech #1090/1265 Spring/Summer/Fall
2001 330Cic/A Fiance-mobile
1991 200 20v Winter/Utility
PostPosted: Sat Jul 10, 2010 11:04 am
anyone have number's on the new aluminum block 5.o Ford for the 2011Mustang? Not likely to be a cost effective option... just curious.
Happy Trails!!!
PostPosted: Sat Jul 10, 2010 11:06 am
It is heaver than a LS1/2/3; just the, cast iron, block is 215#s.
PostPosted: Sat Jul 10, 2010 4:19 pm
forget a V8, try something different; VR6
evan nelson
-Buell XB9SX
PostPosted: Sat Jul 10, 2010 7:14 pm
VR5!
PostPosted: Sat Jul 10, 2010 7:27 pm
Now we're talking!
evan nelson
-Buell XB9SX
PostPosted: Sat Jul 10, 2010 9:00 pm
Well my vote goes to the LSx. It's a well documented swap, and the engine has pretty much had everything possible done to it, has a huge aftermarket, and can make mad power relatively easy. Though an I5 swap would be sweet.
--Josh--
'89 200QT - RIP
PostPosted: Sat Jul 10, 2010 9:26 pm
I would at least consider a BMW engine. I would not want to venture into adapter plate territory, which would be required by an Audi V8. BMW has produced some powerful and reasonably light engines in the past few years. BMW I6s are fairly short, all things considered. Would an I6 be possible in a Miata?
What was the last time we refreshed the Tree of Liberty?
PostPosted: Sat Jul 10, 2010 9:42 pm
http://www.motoiq.com/magazine_articles ... is-in.aspx
PostPosted: Sat Jul 10, 2010 10:32 pm
I like the way you think. That engine is a work of art from what I've seen. Almost on the level of the exotic European V8s like the RS4 and the M3.
-Chris
'01 ///M5
PostPosted: Sat Jul 10, 2010 11:18 pm
Isn't it WIDE?
PostPosted: Sat Jul 10, 2010 11:55 pm
oh probably, but the original poster didn't say anything about physical dimensions... on never mind... Miata right... dunno probably do large.
I know the new Shelby 500 5.4 blocks are aluminum and they are using some sort-of treatment/coating on the cylinder walls instead of the more traditional cast iron sleeves (presumably the same process on the new 5.0 ??)... Yup... pretty trendy, coated aluminum cylinder walls and variable cam timing... all the modern tricks... and in a Ford... its been long wait for sure.
Happy Trails!!!
PostPosted: Sun Jul 11, 2010 1:08 am
new 5.0 has steel sleeves
-Chris
'01 ///M5
PostPosted: Sun Jul 11, 2010 2:32 am
Location: Norton Shores, Mi. My cat has human-like reflexes
Few random thoughts: rover w/turbo (maybe turbo in back of car if you have to) buick 3.8 v6t, or just rods and big turbo for the stock 1.8
7a head/milled mc2 bottom w/holset Hx35...500hp for $500?
viewtopic.php?t=6726
PostPosted: Sun Jul 11, 2010 7:22 am
For a Miata I would consider a 13b rotary engine. Light, documented installations, good power, takes weight off the front of the engine, plenty of room to work on it in the engine bay. Add a turbo & a big intercooler & call it a day.
"Nulla tenaci invia est via"
1990 20v coupes (2 X red)
95.5 UrS6
2002 S4 parting out.
1996 Cabriolet.
PostPosted: Sun Jul 11, 2010 8:27 am
isn't there a KIA motor they stuff in those? (a v6 if I remember) KIA uses it in their SUV and its actually a Nissan engine?
@Lox good to know about the 5.0
Happy Trails!!!
PostPosted: Mon Jul 12, 2010 8:41 am
http://www.h1v8.com
That engine just kicks ass! And for a measly 1200 bucks extra it goes to 3.0L.
Just add 2 turbos and hey presto: 2x 499hp: http://www.youtube.com/watch?v=jwieel03c-w
Or this one. Just sick: A BMW m20 3L: http://www.youtube.com/watch?v=J0gKX2J- ... L&index=17
96 Audi S6 20vt sedan automatic, breathed on.
95 Audi 80 2.0 sedan automatic
  |  It is currently Thu Apr 24, 2014 5:54 pm
