Post new topic Reply to topic  [ 39 posts ] Go to page Previous  1, 2
how to wrinkle paint successfully
PostPosted: Tue Jun 06, 2006 2:56 pm
were not? what????? then what the hell am i doing here?
Nate's Law:
The greater the number of people in the group, the lower the total collective, and individual intelligence of said group becomes.
Audi, imprisoning me, all that i see, absolute horror. I cannot live, i cannot die, trapped in my audi, my audi my holding cell..
1988 Audi 5ktq - 10vt Ms&s Extra
1993 Audi 90q - 12vt
PostPosted: Tue Jun 06, 2006 2:57 pm
I'm compensating for something with this
i dunno son 8)
Ð3Я3К....
86' 4kq~OG Alpine Weiss *Comatose*
83' URQ~project secrecy
85' 4kq 20vt~The Sniper 8) *alive*
01' A6 4.2~6spd conversion, Gallardo 19's*sold*
83' 4ks 2dr*DD protege'*
85' diamond 4kq*DD*
PostPosted: Wed Jul 26, 2006 5:00 am
Just wrinkle painted a valve cover and timing belt cover last night. I used the Krylon Jet Black finish that I found at Auto_zone for around $5 a can (they only had black though).
I followed Derek's directions and made the mistake of not putting on enough paint during the different coats. When the parts dried the first time, they were just black with some speckles... No wrinkles.
I think I'm just used to doing multiple light coats of normal spray paint. Anyway, luckily the directions on the can say that you can add more paint after the first layers have dried if you're not getting any wrinkle effect. I did that and it turned out just fine. In the future, I'll just have to remember to put it on pretty thick...
Next, I found some other websites that talked about this process and they recommended curing the paint in the oven set at 150 degrees. Mine didn't go down that low, so I cooked my parts at 170 F with a bowl of water in the corner of the oven (apparently humidity helps) for around 20 minutes. Worked really well...and appears to be a durable/uniform surface.
00 A4 1.8TQ
98 A4 TDI V6 Avant Q
98 A6 Avant Q
86 4ktq
83 GTI FSP
81 Caddy TD
77 Rabbit ITC
96 Miata
PostPosted: Wed Jul 26, 2006 6:46 am
Send D3R3K your next batch of Chocolate Chip cookies!
I hope you have an electric stove...
1987 elQUANTUMino Project
1990 Pearl Coupe Quattro - Cone Killer
1994 Silver 90Q "Freeda" Snow Beater
1992 Blue Eurovan "5+5" "DasFeld"
1992 Forest Green Cabriolet Project
1988 Red MR2 Supercharged
Future? 1986 AE86 Coupe 1985 GTI
Wife's Ride 2002 Saab 9-5 "Baab the Saab"
Parting 1993 90q 1996 A6Q Avant
PostPosted: Wed Jul 26, 2006 6:49 am
Yep... Electric stove and I live alone, so no one hassled me about using it. We'll see if the next frozen pizza tastes "Kryon-licious".
00 A4 1.8TQ
98 A6 Avant Q
86 4ktq
83 GTI FSP
81 Caddy TD
77 Rabbit ITC
96 Miata
PostPosted: Thu Oct 25, 2007 9:03 pm
Pictures are gone :(
Audi Coupe Quattro
PostPosted: Thu Nov 22, 2007 8:13 am
It's not wrinkle but...I use Napa black bed liner a lot. Depending on the spray distance, you can make it smooth or very coarse. No clue on whether it takes heat or not, but it takes a pounding and most solvents are ok on it.
I use it on the headlight surrounds, rockers and a few other bits.
- Mark
M.Wetzel's Reißend Produckt LLC
PostPosted: Thu Nov 22, 2007 9:25 am
sorry man, blame forum changes :( they are in my gallery though
http://www.motorgeek.com/phpBB2/gallery ... 2a08053920
Ð3Я3К....
85' diamond 4kq*DD*
PostPosted: Sat Aug 29, 2009 5:26 pm
derracuda wrote:
:edit: here's the link to the gallery with the pics since the links aren't valid anymore..
carry on 8)
hey guys, i felt i should do something to the v8, so i grabbed a can of wrinkle paint and took some pics of it so i could give a good method of layin' it out.
materials needed-
favorite brand wrinkle paint (i use Krylon jet black)
scotchbrite or 400grit sandpaper.
masking tape
flat or low gloss black
i totaly blanked on the first prep stage, but luckily it's simple :P , just use some scortchbrite or 400grit sand paper to roughen the surface up and then wipe with some thinner or something. mask off the gasket type surfaces because the paint doesn't quite fully cure until it gets really hot, and the gaskets tend to stick to them.
after you've prepped the surface and it's nice and dry, spray a thin tack coat of the low gloss or flat black. i lay it out so that i can make sure that there is a nice flat basecoat with no fisheyes. if you've got fisheyes, start cleaning all over again :Warning: DO NOT USE SILICONE PRODUCTS AROUND PAINTING...........PERIOD!!!
the end result of this stage should look something like this...
i masked the center of thi valve cover for the simple reason that i sometimes pay too much attention to details and get carried away (yellow calipers aside....i swear it was the paints fault)
the next step is to lay a thin tack coat of the wrinkle paint on......
the next coat will be a medium heavy coat, wait about 5-6 minutes after the first coat to lay this one on..... make sure that you do it nice and even as the wrinkle depth is directly proportionate to how thick the paint is.
the third coat is medium heavy as well, don't make it run though :wink:
it will stay glossy for a while until the paint starts reacting and wrinkling. it goes faster if it's warm out. comparison..
here's the first one i did in the pair.
it's a really durable paint and pretty much always looks good. people have been asking me tips and stuff for doing this for a long time, so here ya go, have fun!
I sorted the imagelinks so lazy ppl (like me) can look at this with ease again. If you copy it over to the first post ill delete this :-)
By the way, thanks for the writeup!
1985 Coupe quattro restoration project
1995 A6 Avant 2.5 TDi
PostPosted: Tue Jun 01, 2010 3:04 pm
I've got the eastwood powdercoating kit, you can get powder that finishes quite similar to this.
 Post subject: Re: how to wrinkle paint successfully
PostPosted: Sun Oct 17, 2010 12:01 pm
I painted my intake mani with the high heat enamel, and because of the rough surface it looks alright. I'm not liking how glossy my valve cover came out though... thinking about doing wrinkle
1991 glacier blue 200 20v - DD
1991 titan grey 200 20v avant - project
Porsche 914 2.0 - Track car?
1983 Toyota Tercel SR5 4x4 - the beater
1986 Honda VFR750F - Just to make my cars feel slow
1995.5 S6 - wrecked and gone, selling parts
PostPosted: Thu Apr 07, 2011 11:46 am
This is how my valve cover came out with VHT wrinkle paint, very slight wrinkle.
-Matt
04' Laser Red Ultrasport A4 1.8t Avant
 Post subject: how to wrinkle paint successfully
PostPosted: Wed Aug 22, 2012 10:54 pm
hello how do i change the background colors and text colors etc thanks for your time take care
PostPosted: Thu Aug 23, 2012 12:35 am
Location: Near Sacramento. Sometimes at Derracuda's place(Oregon)
^^^ troll bot.
Dan.
1985 4000S Quattro AUX 40V 4.2 - Now with 3" 304SS Exhaust.
1990 Jetta GLI 16v
1989 Jetta Coupe
4 Toyota 4x4's
1969 Plymouth Roadrunner- SOLD 5-7-11
1970 Boss 302 Mustang(Roadrunner replacement)
2006 Yamaha WR450
cron
  |  It is currently Thu May 23, 2013 7:46 pm
