motorgeek.com :: Board index :: The Tech Lounge :: Suspension
Post new topic Reply to topic  [ 108 posts ] Go to page Previous  1, 2, 3, 4, 5  Next
The DIY Coilover page for 80/90/Coupe
PostPosted: Wed Apr 21, 2010 10:01 am
chadlundy wrote:
alright, i will definitely look into some sport shocks! what spring length and rate should i use for a little tire tuck and fast cornering/handling??
Chad, do some searches and browsing on this. Its very subjective. One mans Aggressive track setup is another mans Street setup. Basically though.
8" Springs should give you adequate lowering with most rates you would run on a street car. If you want to Slam it you may need 7" but thats not good for maximum handling.
For rates.
I'm going 300f/325r. That should be firm, far better than stock, but still civilized.
As you approach the 400lb rates, handling gets more track car like, but your street-ability will suffer. Many run these all the time on the street but I find it a little stiff for a daily driver.
500lb and up is Track only.
Also, the stiffer the springs, the more dampening you need. Most Koni's / Bilsteins are designed for softer (Street lowering springs). They should match up ok to a 300lb spring. If you put 450lb springs in there, they are under-dampened.
Todd
91' CQ Daily Driver (FOR SALE)
2000' A4 Avant ATQ
83' ur-quattro. "Jadis" Cage, Coilovers, No Engine Yet.
"Coupes are better than Sedans. Less Door Handles to replace!!!"
PARTING:
90 90q20v
86 4000quattro
PostPosted: Wed Apr 21, 2010 10:04 am
:thanks: Well put. It seems some times things can be raked back and forth forever and I like seeing good posts like this.
PostPosted: Wed Apr 21, 2010 10:07 am
ok, i understand it alot better now! so heres the thing, i dont want to slam it, but i want it to look good and handle better! will i be able to get 1.5'' of lowering with the 8'' spring? or will i need the 7? thanks for the rates!!
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
PostPosted: Wed Apr 21, 2010 12:38 pm
For the rear 8" no problem.
Front you have less adjustment because of the Tie Rod arm. I believe you have to cut down the threaded perch in front. In the front 8" should be fine but 7" might also work. I'm going 8" all the way around but I only want to be about 3/4" - 1" lower.
Todd
2000' A4 Avant ATQ
PARTING:
90 90q20v
86 4000quattro
PostPosted: Wed Apr 21, 2010 12:39 pm
You know, on your 88 I might do 7". CQ is a lot heavier with 20v, Coupe body, Glass Sunroof, etc.
Todd
2000' A4 Avant ATQ
PARTING:
90 90q20v
86 4000quattro
PostPosted: Wed Apr 21, 2010 12:56 pm
alright! i think i might do 7'' then... would 6'' in the front be to much you think?? or do you think i would be ok?
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
PostPosted: Wed Apr 21, 2010 1:18 pm
Hey, I just replied to your post in the other thread.
Yes I personally think for Handling and overall street performance your better off with a 7" Spring in the rates your looking at. If you were going with 600+ lb springs like SpeedingG60 then 6" might be the way to go.
I think with 375lb fronts in 6" you can either slam it or keep it lowered but why not just use the 7" which have more theoretical travel capability, and should still allow lowering. I'm going 8". On my other car I have 10" all the way around but I cant lower it. Stock or higher only on a 2700lb car. Logic tells me that with 8" in the same rate, I should be able to lower the same 2700lb car by 2". A 3,000lb car by a little more. 7" should allow you Plenty of lowering.
Todd
2000' A4 Avant ATQ
PARTING:
90 90q20v
86 4000quattro
PostPosted: Wed Apr 21, 2010 8:29 pm
Awesome! thank you!! i think i will definitely go with the 7'' all the way around... well see, i just want it to handle better!!
-chad lundy
88 Audi 90Q 10v
90 Audi 90Q 20v
90 Audi V8Q 32v
91 Audi 200 20v
 Post subject: Re: The DIY Coilover page for 80/90/Coupe
PostPosted: Sun Dec 05, 2010 9:55 am
and an update; http://www.CompBrake.co.uk has great solid top mounts....
759 AWHP, 554 wtq @ 38 psi in a 20v 2.0L 4 cyl Coupe Quattro. on E-98 and 67mm billet turbo
9.342 @ 153.71 1.400 60' and pulls 1.6g on acceleration! 60-130 in 4.9 seconds
QUICKEST 4cyl Audi Quattro drag car in the WORLD!! And now QUICKEST AUDI IN N AMERICA AS WELL!!!!
My Website
PostPosted: Thu Mar 03, 2011 6:48 pm
Anyone know if the threads on the A1 stuff are compatible/similar to the ground control perches and collars?
Sam
Sam 'Poser' Stone
1990 Coupe Quattro 20vt Conversion w/ 034EFI IIc
http://www.imolamotorsports.com
PostPosted: Thu Mar 03, 2011 8:51 pm
Same stuff, Sam. I replaced some collars and re-used GC perches a while back...on the front I used one A1 sleeve cut in half for 2 struts...
Peter
PostPosted: Fri Mar 11, 2011 9:03 am
Is there anything wrong with the Hyperco springs on A1s site? I was thinking 7" 350# for the front and 8" 400# for the rear on my CQ.
Brent
2001 A4 Avant 5MT Pelican
1991 CQ - Project Car
PostPosted: Fri Mar 11, 2011 9:14 am
hyperco makes nice springs
BEAST http://www.motorgeek.com/viewtopic.php?f=6&t=40366
DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.motorgeek.com/viewtopic.php?t=34308
'86 4kq - 3b'd = gone http://www.motorgeek.com/viewtopic.php?t=25432
PostPosted: Fri Mar 11, 2011 9:46 am
I can't speak for HyperCo springs but I can add some input on the SuspensionSpecialties ones. Long story short - I started out my project with SSS blue springs at 350F / 400R. While assembling the fronts I noticed the VERY close fit from the inner surface of the springs to the cap that holds the strut into the housing. I had a set of 2Bennett's in the proper rate so I did the final assembly with 2Bennett on the front and the SSS in the rear. The rears were extremely tight near the cap as well but I decided to just run them as I was pressed for time. The inner surface of the spring rubbed quite angrily against the strut cap making this the most janky sounding set of coil overs I had ever experienced.
With the the tail end of the car taken apart to fix the tie rods I decided that there wouldn't be a better time to fix the rear springs. When I lifted the car I could see the finish worn from the inner surface of the springs and the outside of the strut cap abraded to a nice shine. I ordered up another set of springs from 2Bennett and swapped them out. The 2Bennett's are wound to 2 1/2 inch at the bases but slightly chubbier in the mid section to clear the strut caps on Audi.
Some have mentioned other springs that have similar dimensions but I don't recall who they are. I ended up with a 2B 8" 350 front and 9" 380 rear combination which is very close to what I felt would be ideal. It's not on the ground yet but Im anxious to see how this combo works (and sounds).
More details in my project thread search 'Blue Pill' Since this was a sticky I felt it worth sharing. I also use and LOVE the CompBrake top mounts that Aaron displayed above. For anyone that has attempted the painstaking removal of the rear struts on an UrQuattro I can tell you that you can completely drop the rear struts without pulling the rear seats and the package shelf. You can access the spanner nut on the ComBrake units from the trunk of the car just by pulling down the carpets.
Abarth
Integrale'
Coupe Quattro
UrQuattro
Lancia Scorpion
PostPosted: Fri Mar 11, 2011 9:57 am
Does anyone here run helper springs, I think I'm going to with shorter springs.
PostPosted: Fri Mar 11, 2011 10:00 am
timmmmmmay does and so will myself shortly
PostPosted: Fri Mar 11, 2011 10:12 am
I do.
With regard to soteriology, show me a man convinced of his volition, and i'll show you total depravity.
90 Corrado GTB2260VK "TDI RatRod"
91 CQ "The Pale Horse"
93 Eurovan
96 LX450 the "Yetti"
Lemond Tete with added lightness
Trek 930 Road convert
Schwinn urban assault bike
Centurion "Kris Cooper commemorative edition" Gearing is fixed, but its got more than one speed!
"All men are squids." -John Calvin
PostPosted: Fri Mar 11, 2011 11:09 am
I do, but Im curious why you'd want to run shorter springs?
SSS Springs:
2Bennett Springs:
Both use components from A1 Racing and Pitstop USA, Including helper springs and perch.
Abarth
Integrale'
Coupe Quattro
UrQuattro
Lancia Scorpion
PostPosted: Fri Mar 11, 2011 1:18 pm
Yeah, I knew Haydn did. I wasn't sure how much they compress and wasn't sure if you'd need 1" shorter or more..? Thats all..
PostPosted: Fri Mar 11, 2011 2:18 pm
the reason for the helper spring is to keep a load on the spring in an unloaded full rebound (wheel in the air? car on a lift??) situation. so the spring will not clank around in there and have a chance to not seat properly upon compression.
at least, that is what i know of them. and i do not run them for the simple fact that mine do not unload during use. and that $$$$ was better spent elsewhere.
i do have gap from hat to spring when jacked up, BTW. but my rates are 650 frt and 1000 rr. and i only go straight.
My Website
PostPosted: Fri Mar 11, 2011 2:24 pm
also, if you look closely at my pictures, both the Eibach and the QA-1 springs have plenty of internal clearance to the strut cartridge nut.... and the QA-1 has more by far as well, over the Eibach.
the reason i used the Eibach in the rear was due to the fact that the QA-1 did not go past 650 lb.
My Website
PostPosted: Sat Mar 12, 2011 10:19 am
Good to know, I always thought the QA-1 springs were really thick.
Brendan
'93 Corrado SLC
'05 New Beetle TDI
'86 Golf Diesel, rebuilt engine w/ turbo
'81 Scirocco 'S <-TDI swap soon!
PostPosted: Mon Mar 14, 2011 6:36 am
So, would this work for a helper spring? And is there anything that goes between the two springs?
http://shop.a1racing.com/HYPCS100.aspx
Brent
PostPosted: Mon Mar 14, 2011 7:22 am
there is a small collar/hat/seat thing that goes between the spring and helper spring
PostPosted: Mon Mar 14, 2011 7:35 am
where would one find that piece?
Brent
  |  It is currently Fri May 24, 2013 7:52 pm
